"Shaded with edges" mode's not available
Hi everyone, I'm a newbie in Revit. I'm using Revit 2017 student version here. As I know, there's "Shaded with edges" mode in Revit but I can't see it. I attached a picture to show you the problem. I don't know if it just me or something, can you guys help me please? Thank you so much!!!!!
chrisplyler
Nope. Your list shows every mode.
Shaded mode is default with edges visible.  If you want them off (I know you didn't ask for it), then untick the box below:
Viveka_CD
Hi @Anonymous
I see that you are visiting as a new member. Welcome to the Autodesk community! Smiley Happy
Please click on graphic display options select 'shaded' in the styles drop down and check 'show edges'
You can also go to the
  • Properties palette (for the view)Graphic Display OptionsEdit
Please select the Accept as Solution button if my post solves your issue or answers your question. Kudos welcome!
