第 1 条消息(共 9 条)
Hello dear members of the Autodesk forum,
I'm using Revit 2021.1.6 and trying to create a multifunctional annotation for multiple air terminals. So far I've used calculated parameters with IF-THEN-ELSE functions. Now I am faced with the challenge that an empty field or no content should be output for a parameter with the type for the length if case "false" is outputed. As "". But "" is usable only in a text parameter and I need a space in a length parameter. I've tried outputting 0 in case of false and making 0 invisible, but I have no idea how that's supposed to work. Are there other options for this challenge?
Thanks in advance: Konrad
已解决! 转到解答。
