"Highlighted lines overlap" when creating Extrusion in Family
fletcherCAUUG
fletcherCAUUG
Hi there,
I am attempting to create a Family in Revit of a 'cardboard cutout' of a pot plant. I have been doing this by importing a DWG outline of a pot plant, and then using the Pick Lines command to extrude the lines. My problem is that when I Tab-Select all the lines I get the warning "Highlighted lines overlap. Lines may not form closed loops". Even though outside of the extrusion 'mode' , there appears to be no overlapping lines? I am wondering whether it is to do with the DWG being made of splines? Any ideas on how to solve this?
I've attached the Revit file below.
Thanks in advance.
vitorbortoncello
Convert your dwg outline spline to polyline
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | BIM Manager
dAutodesk Certified Professional
fletcherCAUUG
Cheers!
