Question regarding Views with Shared/Project Parameters in them
mroble
mroble
Revit 2019....
This is kind of a general question as this spans several disciplines inevitably, so I'm posting it here.
I created a View for a "T/Platform" level... Level Name, and subsequently the name carried over into my View Title on my sheet, was "T/Platform Plan"...
His markup asked me to rename the View Title to say "T/Platform (Elev. xxxxx, T/Steel Elev. xxxx)"
Easy enough to do, I just renamed my view to accomplish this, but the issue I have is that I now have to stretch my View Title family to account for this. Which, 9 times out of 10 is probably NOT going to be what I'll want. Even in other plans on this same project.
My thought, "I'll make a Shared Parameter (Text format, not "Length or anything) in my Global Shared Parameter File, named "View Description"... and make this a second line in my View Title, or third if my first line wraps, but I digress....
I added that to the label in my View title in that manner. I saved it, loaded it, I applied that View Description as a Project Parameter in my project file, applying it to only Views, but if I highlight a View, despite being able to see this in my properties, it's shaded out and i'm unable to modify.
What gives?
mroble
It was locked down as "included with" whatever view template was assigned.
By doing this, I'll just have to do this work I mentioned above, and then go "un-include it" from all view templates.
https://forums.autodesk.com/t5/revit-architecture-forum/project-parameter-grayed-out-in-properties-p...
You can create a Multi-line parameter ans use it for the label of the View Title. Then, you can break the text anywhere you want.
mroble
Thank you sir...
I had already added the shared parameter, and fixed it to not be included with the templates, but I am going to put a pin in this so if this gives me issues, I'm holding on to that.
Keep in mind, I'm firming up a template, the comment came from a recent project, but I am trying to address these kind of things in the new template.
