Project parameter grayed out in properties pallet
9 ANTWORTEN 9
GELÖST
Nachricht 1 von 10
10920 Aufrufe, 9 Antworten
Hello, currently my project browser is bit messy. so I planned to create sub-discipline folder so that I can move some of the secondary plans.
Initially, I created a project parameter Sub-discipline but it has been grayed out in the properties pallet. I cant enter any values.
can anyone please help me to fix the issue.
9 ANTWORTEN 9
Nachricht 2 von 10
ennujozlagam
als Antwort auf: Anonymous
hello, did you assigned your parameter data into categories VIEWS? thanks
Nachricht 3 von 10
als Antwort auf: ennujozlagam
Yes! please find the attachment.
Nachricht 4 von 10
ennujozlagam
Maybe change the group parameter under - identity data and see if helps. Thanks
Nachricht 5 von 10
Hii. I changed as Identity data. still,l it's the same.
Nachricht 6 von 10
Alfredo_Medina
Most likely the view that you are trying to change is controlled by a view template, and that new parameter is checked as "included" in the settings of the view template. If that's the case, go to the settings of the view template that is assigned to the view, scroll to the bottom of the list, find that parameter and uncheck it from the "Include" column.
Nachricht 7 von 10
ennujozlagam
I think @Alfredo_Medina is correct. It controlled by your view template lift lobby detail, try to set to none. Thanks
Nachricht 8 von 10
kristdan
als Antwort auf: Alfredo_Medina
Yep saved.
Template ON
Nachricht 9 von 10
cnupsonYBUUR
I had my project browser parameter organized by Constraints and now it is gray. Could this happen because I saved from the cloud to my desktop? I tried creating another browser and placed that under Identity Data but it is still gray. Not sure why. Can you help?
Nachricht 10 von 10
als Antwort auf: cnupsonYBUUR
Your View Template control that parameter.  If you want to change that parameter value per View, edit the View Template and untick the box next to that parameter name.
