PTS scan not indexing
FYI this issue also occurs in Revit 2018.2 when importing PTS scan and Indexing to RCP.  It's processing, but progress bar doesn't work:
Viveka_CD
Hi @Anonymous
I'm checking back on this post.
How big is the file? Does this happen with other files? Can you navigate to the support folder and check if it has an RCS file?
I attempted a few scans. After about 4 hours, the progress bar would say 100% complete, but the RCP file was only a few KB, and the RCS only 103KB. This coming from a 106 GB PTS file. It failed it index every time in Revit.
I then attempted in ReCap Pro, and the same thing happened on the first attempt. No progress bar and failed to index properly.
After that, I updated ReCap to the latest version and then indexed. It then successfully indexed to a 6 GB RCS file, but failed to show progress bar during the operation in ReCap.
Viveka_CD
Hi @Anonymous
Let me check with a ReCap specialist on this issue.
However, we would need a journal and your file to test and compare results once we reproduce this issue.
I can share a private folder to upload. Let me know.
We look forward to your reply update.
Viveka_CD
@Anonymous I found this idea regarding progress bars. You are welcome to add your comments to this idea.
I'll post here if I have an update.You can also try posting on the Recap forum for further feedback.
Viveka_CD
Hi @Anonymous
I also wanted to share the ReCap release notes with you which has some major bug fixes related to indexing large files.
