Providing perpendicular cut in Topography
11 REPLIES 11
Message 1 of 12
salmanjavaid2000
820 Views, 11 Replies
salmanjavaid2000
Hi Guys!
Is there a way to provide a perpendicular cut in topographic surface? I want to excavate the soil perpendicularly instead of sloping on two sides.
Thanks in advance 🙂
Hi Guys!
Thanks in advance 🙂
Tags (3)
Labels (2)
11 REPLIES 11
Message 2 of 12
Sure, use a Building Pad.
Message 3 of 12
salmanjavaid2000
That will cut the surface, but then I also have to fill it up.
Message 4 of 12
You want to dig a hole and fill it in?  Not following. Can you elaborate?
Message 5 of 12
salmanjavaid2000
The volume is still zero with Building pad
Message 6 of 12
salmanjavaid2000
As you obviously know that we have to excavate the soil for the construction of foundations and then fill the soil back as well, in case there are some spaces available for it. And here in my case there is an isolated footing, for which I want to calculate the cut volume and fill volume of soil.
I hope this helps
I hope this helps
Message 7 of 12
No it isn't.
 Sounds like you are trying to calculate cut/fill.  Is that about the size of it?
No it isn't.
Message 8 of 12
salmanjavaid2000
Yup. I want to calculate cut and fill.
Yes the volume is zero, if you look into the Properties bar on the left side
Message 9 of 12
In order to calculate cut and fill, you are going to need to work in Phases with Graded Region Copies. It's a lot to explain in a post.   It's pretty involved.  See if this Screencast helps your understanding.
Building Pad Cut&Fill Data from Graded Region Copies of Split Surfaces | Search | Autodesk Knowledge...
...here's another one:
About Reporting Cut and Fill Volumes on a Site | Revit Products 2016 | Autodesk Knowledge Network
Message 10 of 12
You want to go from the native site condition to the excavation to the backfill - with cut/fill calculations along the way.  Is that about the size of it?  If so, you'll need 4 Phases.
Message 11 of 12
By the look of it, you are selecting the wrong Toposurface in your above screenshot.  If you've done it correctly, there are 2 Toposurfaces. Select the Topo infill that is created automatically when you create a Building Pad.  That is the one that reports Cut/Fill quantities in its  Properties.  The other, surrounding Toposurface reports zero quantities for Cut/Fill.
Message 12 of 12
salmanjavaid2000
It worked. Thanks a lot
