Curtain Wall Legend Components
2 REPLIES 2
PhilvK
8764 Views, 2 Replies
I am trying to create a legend of my storefront assemblies so that I can dimension only the storefront without showing the adjacent building parts. When I go to insert it as a legend component on a legend sheet, I only get plan and section as options. I assume this is because my curtain wall ‘window’ is really a ‘wall’. Is there a way to get curtain wall windows to be legend components?
2 REPLIES 2
Keith_Wilkinson
in reply to: PhilvK
Hi Phil,
Scheduling out curtain walling is tricky.  legends don't work simply because of, well, the way legends work.
What we usually do here is set up separate elevation views for the legend and place all the curtain walling on a workset called 'Curtain Walling', then in the view we are using as the legend we just have that 1 workset on.  In general we've found this to be the cleanest way to deal with the problem and it has the big advantage of always being current and fully tagable.
K.
"Give a man a fish and you feed him for a day; teach a man to fish and you feed him for a lifetime."
Maimonides
dingohot
in reply to: PhilvK
Forma Design Contest
Technology Administrators
