Properties - home & End Keys
10 REPLIES 10
Message 1 of 11
604 Views, 10 Replies
After starting to type text in the properties window the home and end keys no longer function.  They work as the first key typed but not after that.  Is there something I can do to get them to function?
Matthew
Revit 2017 & win 10
Matthew
Revit 2017 & win 10
10 REPLIES 10
Message 2 of 11
tuuletin
tuuletin
Maybe, to use the page up and page down keys?
Message 3 of 11
jonathan_moreno
jonathan_moreno
Can you try a different keyboard?
Use CTRL+Home to go to the beginning and CTRL+End to go to the end.
Keyboard shortcuts
Jonathan M.
Technical Support Specialist
Keyboard shortcuts
Jonathan M.
Message 4 of 11
in reply to: jonathan_moreno
I also noticed that the arrow keys do nto work in the properties window after I start typing.  I think it is not the keyboard.  These keys work directly after the initial click intot the edit box.
Thank you for the suggestion.  I'll give is a shot.
Matthew
Matthew
Message 5 of 11
ctrl+home or ctrl+end do not work.
Message 6 of 11
jonathan_moreno
jonathan_moreno
Can you please create
- A Screencast video (or a video from some other screen recording utility) showing the steps you are going through.
I was not able to reproduce:
http://autode.sk/1TIctan
Jonathan M.
Jonathan M.
Message 7 of 11
Jonathan,
Your screen cast works exactly like it does here.  You have to type some keys and then hit the home key. After typing in some text to an edit box the home key wil not work.
You need to add 1 more step before hitting the home key.  Try to change the name of something and then hit the home key.
HTH
Matthew
Jonathan,
HTH
Matthew
Message 8 of 11
How about this one? I have not done this before, so I hope it works.
http://autode.sk/1NSD6a7
Matthew
Matthew
Message 9 of 11
jonathan_moreno
jonathan_moreno
Hi Matt,
Can you make it unlisted or public?
Do you know if this works in previous version?
Jonathan M.
Hi Matt,
Jonathan M.
Message 10 of 11
I thought I changed it to public.  Um I do not remember if it worked in 2016. I have only worked it Revit for about 6 mo.
Matthew
Matthew
Message 11 of 11
jonathan_moreno
jonathan_moreno
This incident is currently being investigated for a possible cause and resolution.
Jonathan M.
Jonathan M.
