Exporting multiple Revit sheets to a single AutoCAD file
3 REPLIES 3
1165 Views, 3 Replies
I am currently using Revit 2014.
I am looking to export several sheets from Revit (ex. floor plan, plumbing rough-ins, elevations) to a single AutoCAD file.
Is there such a thing? I am looking for the simplest way to do so.
Justin
3 REPLIES 3
Sorry, no easy method.  You would have to merge the sheets and views within Autocad.
Is there a reason you have to do this though?  That would make it difficult to use for coordination.
Do you mean manually?
chrisplyler
My sense of logic tells me no. How would Revit know how you wanted to position each sheet or view within a single Autocad file?
Forma Design Contest
