Project with graphic issues
Following our graphic issues with our templates and project, I have another different one.
https://forums.autodesk.com/t5/revit-architecture-forum/template-corrupted-with-graphic-issues/td-p/...
I thought it was a problem in our company revit template, but I have used the default Architectural Template from revit, and I have the same.
I open a new project, and insert a dwg with a survey.
If I insert it positioning Auto - Center to Center. The lines are ok
If I insert it positioning Manual - Center. the lines aren't straight as bellow. See the dwg in Autocad and in Revit
Does anybody know the reason?
I had this exact issue a few weeks ago.
The issue is the coordinates in the cad file are too far from the coordinates in the revit file.
You need to create a copy of the DWG file, and move everything to 0,0,0 in the model space, then link that into revit.
https://forums.autodesk.com/t5/revit-architecture-forum/revit-dwg-snap-bug-and-wonky-lines/m-p/74778...
I have tried it and it works moving the drawing close to the origin
