how to set the level symbol distance from view automatically
RKS_PRECISION
RKS_PRECISION
i have a lot of internal elevations, and i need to set the level symbol distance from the view crop automatically so i don't have to set them individually.
i mean that it is automatically created like attached
i need it to be created extended out of the view
kadmonkee
I dont beleive it is possible to get the result you want.
how is Revit going to know where to place the level heads?
each new section or elevation will need adjustments of some kind
it relates to the Size of your Elevation area see grips in the image.
if you dont need the level heads displaying on both sides you can cut your adjustments in half
If there is any information shared that is of value please give Kudos
If a solution is provided by any posters please mark them as Solved to benefit everyone else.
thank you
Hello @RKS_PRECISION
Its already existed but because you crop specific area from elevation you can't see level symbol ,to fix that, just expand your crop box so that you can see levels when it appear drag it to your small elevation scene
It is hard-coded into the program.  The default distance from the edge of the viewport to the end of a level line is 25.6 mm or a tad over 1" unless you deliberately grip stretch it afterward.
