I have the Revit Student Version 2017. On the download I did not get the Projects Templates for Imperial in English. The Family Template Libraries are there. Tried doing the Install/unistall procedure through thre windows control Panel and doesn't work. Where can I get the Projects Templates for downloads?
Solved by ennujozlagam. Go to Solution.
hello, you can check it here. thanks
