Associating a nested type parameter to a parameter in the host family
Hi all
Following a tutorial (they use Revit 2013) on how to make a parametric ladder using arrays...they nest an extrusion (that of a step with a type parameter LxWxD) into a line based family where they make the array.
In the line base family they go to project browser under families and right click the extrusion (generic model step) and assign the L_Length (which is a originally type parameter) to the default Length parameter in the Line based family.
When I do the above...and go to the type parameter of the nested step...there is no button to associate its L_Length to that in the line base!
I am using 2016, did something change?
Accepted solutions (3)
rodrigo.bezerra
Hi
Nothing changed. The nested family parameters must be per instance, even if the equivalent in the host family is per type.
Regards
Rodrigo Bezerra
@rodrigo.bezerra
Thank you so much for your reply. I will try instance see if it works
but can you have a quick look at this YouTube video http://youtu.be/TxTsGMSIUFY  (start minute 8 to 12) this is the one showing type parameters in the nested family and he can still associate parameters to them in the host line base
I just want to make sure I am not learning something wrong!
thank you again for your kind help
rodrigo.bezerra
@Anonymous
I watched the video. Yes, he did as a type parameter in the nested louver family. Although I didn't quite understand why he put inside a line based, to do the curtain panel. I do louvers without the line based step and works pretty fine.
You may upload your families so we can take a look, if you don't mind.
Regards
Rodrigo Bezerra
RDAOU
It used to be the case at least in version 2013 and 2014...Nested Type Parameters could be associated previously with an Instance or Type parameter from the host family.
I am not sure about version 2015 I never used it...but definitly in Revit 2016 past R2 Release you cannot do that. It has to be the as @rodrigo.bezzera suggested (instance parameter)... not sure when exactly that was changed R2 UPD 2, 3 or 4 - I know for sure that R2 UPD4 messed up lots of things
It should also be doable without the line base family step (if just an array of that extrusion is what you are after)...that line based family step is more for placement purposes when you instert/nest the blade/lover into a curtain panel system panel (2 pts placement makes it tidier but does have its cons too)
 Printscreen below from 2014
RDAOU
@Anonymous
Revit 2016 Update 5 has been released... I have just checked and it resolves the issue you mentioned...One can now associate Type Parameters in nested families to those of the host family
You can either download from account management, Autodesk desktop app or the link below.
http://up.autodesk.com/2016/RVT/Autodesk_Revit_2016_R2-x64_UPD5.msp
rodrigo.bezerra
Found out yesterday that nested shared families cannot have their type parameters driven by the host's parameters (Revit 2015). Did not test in other releases yet.
Regards
Rodrigo Bezerra
