Hello
Can someone provide me with the procedure/advice/links for saving a RVT file originated by Revit 2020 to Revit 2017 please?
We have upgraded to 2020 however some of our vendors havent so we need to be able to save to an earlier version
Rachel
Solved by manuelmunoz87. Go to Solution.
Sadly you can't. Revit is not backwards compatible. Any files you open with a newer version will be (upon save) upgraded to that version and no longer compatible with older versions of Revit 😞
Hi there
Thanks for the fast reply
The IFC is there limitations with this export facility?
100% agree with the upgrade requirement for our projects
Rach
