Door opening width cannot be edited
5 REPLIES 5
HeadbuttJ
1570 Views, 5 Replies
HeadbuttJ
I edited a door family to try to turn the originally closed door to be opened. I rotated and moved the glass panel to be the open position. But after load family into project, the glass door panels are not located in both sides of the door frame but in the middle.
By the way, can I also make it to be similar to other defaut standard doors which I can change the width by selection instead of modifying one by one by each width?
Thanks very much!
Thanks very much!
5 REPLIES 5
mauricio_mssf
in reply to: HeadbuttJ
mauricio_mssf
You need to lock the door panels to the reference planes (align then constrain the lock).
You can create a dimension parameter for the door panel that is the width of the door / 2, and link this parameter to the door panel.
If the answer solves your problem, click Accept as Solution this helps other users to quickly find an answer and let a like if you liked it.
Você achou esta postagem útil? Sinta-se à vontade para curtir esta postagem.
Ficou satisfeito com a resposta à sua pergunta? Nesse caso, clique no botão ACEITAR SOLUÇÃO.
 Mauricio Santos Filho Arquiteto | BIM Manager
Revit_Whisperer
Revit_Whisperer
I edited the workplan for the panels accordingly and added a parameter for the width...try the attached.
Revit_Whisperer
I added a parameter for the panel width...I wasn't specific =/
HeadbuttJ
in reply to: Revit_Whisperer
HeadbuttJ
I can see you have set a new parameter on the panel width, but I cannot figure out what you have done on the work plane to make the door panels stick to the frame....😅
Revit_Whisperer
Revit_Whisperer
I added the panel width parameter, then for the formula it is Width/2
