Procedure for Saving 2020 to 2017
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
ramcfarlane
488 Aufrufe, 4 Antworten
Hello
Can someone provide me with the procedure/advice/links for saving a RVT file originated by Revit 2020 to Revit 2017 please?
We have upgraded to 2020 however some of our vendors havent so we need to be able to save to an earlier version
Rachel
4 ANTWORTEN 4
Nachricht 2 von 5
manuelmunoz87
als Antwort auf: ramcfarlane
Sadly you can't. Revit is not backwards compatible. Any files you open with a newer version will be (upon save) upgraded to that version and no longer compatible with older versions of Revit :enttäuschtes_Gesicht:
Nachricht 3 von 5
Ask them to upgrade. Else, export to IFC and send it to them.
Nachricht 4 von 5
ramcfarlane
als Antwort auf: manuelmunoz87
Hi there
Have you utilised the IFC Export facility as I exported a 2021 Revit file then opened into 2018.
The project file opened however wasn't entirely successful I do believe it's a variable I haven't selected
Rachel
Nachricht 5 von 5
ramcfarlane
als Antwort auf: ToanDN
Hi there
Thanks for the fast reply
The IFC is there limitations with this export facility?
100% agree with the upgrade requirement for our projects
Rach
