Problems with Revit Graphis
I am having a problem with the graphics in Revit, objects are not lining up and appear to move when zooming in. Objects look as though they are not connected and when I try to pick lines I often need to select well away from the line to pick it up.
ennujozlagam
hi, try to go options > graphics > use hardware acceleration (untick). and see how it goes. thanks
Hi, Thanks for the advise, still haven't worked after I untick - use hardware acceleration.When I go to options a message comes out saying Untested Environment (We regret that the installed video card (AMD FirePro V3900 and driver have not been tested with the currently installed OS/ DirectX version combination.
ennujozlagam
Hi, then try to install the latest graphics card driver.
Hi Thanks for the advise. I have installed the drivers but didn't work, we are going to upgrade the video card too, and will let you know what happens. Thank you
loboarch
The kind of behavior you are describing is sometimes caused by drawing elements very far from the internal 0,0 point of Revit. This could also occur if somehow you have a DWG in the project that has been created a long distance from the 0,0 origin. I would check if you have something very far away from the origin.
Jeff Hanson
Principal Content Experience Designer
Revit Help |
