Problem
Problem
bdarcel345
Observer Observer
Problem
bdarcel345
Observer
Observer
Can  we actually create a brick wall in Revit ?? Like when we will choose wall it is a brick wall that we actually create with details not a generic wall with a brick material
You mean model the individual brick units in the wall? Sure. Use a Curtain Wall.
...maybe do grout with Mullions - if you want to go there.
Or a Pattern Based Panel on a Divided Surface. You can choose a 1/2 Step or 1/3 Step Pattern.
syman2000
You most likely have to create custom family to get what you want. Here is a sample perforated brick family download from Revitcity and reverse engineer the family what you need.
bdarcel345
Observer
Observer
No actually without using the curtain wall method
bdarcel345
Observer
Observer
Thanks Bradley i'll try out this one
Though i wanted like when you go to wall in the Architecture tab it is a brickwall we create with all the details
