Problem with sorting & grouping in Project Browser
s328255
Observer Observer
s328255
Observer
Observer
Hi all,
Here, I want to categorize each of my plans based on real situation, starting from the lower levels at the bottom, and continuing up to upper levels. I defined a Project Parameter named as "Plan Type" in which I use it as for each floor plans. However, when I want to sort my Project Browser from bottom to top, nothing changes except the subsets of each floor plan.
I have tested different things like switching from Ascending to Descending and vice-versa but still unsuccessful.
THANKS
Revit version:  2024.3
akshay_surveKTDLP
Hi @s328255, thanks for reaching out on Revit Architecture Forum.
When you are mentioning about sorting floor plan from Bottom to Top, did you mean 03. Third Floor should show on top in floor plan and followed by 02. Second Floor and the 01. First Floor?
Akshay Surve
Autodesk | Technical Support Specialist
arq_42
I think your problem is using the view type to organize the level, when that parameter already exists.
You can:
A) Remove the type from the organization and organize only by view family. Then sort by associated level descending.
Or:
B) Keep the type in the organization and sort by Family and type descending.
If you really want to maintain the two-level organization/grouping, I recommend using letters in reverse:
Lvl9 = "A. 9th floor"
Lvl8 = "B. 8th floor"
Lvl7 = "C.  7th... "
Mezzanine 1= "J. Mezz1"
Lvl0= " K. "
Lvl-1= "L. Basement 1"
Lvl-2= "M. Basement 2"
I also recommend considering whether you could solve this by creating a shared parameter and applying it to views and sheets instead of using the types.
¿Te resultó útil esta publicación? Dale "Me gusta".
¿Tu pregunta fue respondida correctamente? Haz clic en "ACEPTAR SOLUCIÓN".
CGBenner
Did the information provided by @arq_42 answer your question? If so, please use Accept Solution so that others may find this in the future. Thank you very much!
If you still need help please feel free to provide an update here so we as Community know how we can help you best moving forward.
Chris Benner
