Stair with landing at starting path
4 ANTWORTEN 4
Nachricht 1 von 5
3349 Aufrufe, 4 Antworten
Guys, couple of  question with regard to revit stairs and in specific with landings:
I need to draw a staircase that start from one level up to the upper but with a landing as a first element. If I create the stair with following the DWG but using straight ramp  and a land by edit sketch, it comes out with errors:
1  the land cannot have the size height of 17.65 if the relative height is the same...( which is quite common) because it appear a warning message saying that one or more parameteres of stairs are not valid and,
2 creating the uplifting raisers in aim to reach the floor ...they start lower from the height desired,  (which is 17.65) , unexpectedely, with a first raiser high  two sized of the normal height. In addiction to the message error another warning message receved when trying to fix the heigh...and it does not have any sense for me: Chosed 300cm as top elevation height  (which is the level second floor), the W message says <Top elevation height cannot be lower that extend under the lower base value>..but it is 0 cm! I reported each situation..
I can argue more information on my stairs if you need.
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: Anonymous
I have created a landing and then went with the staircase before. Once I am done creating it, I set the Base offset to negative what the relative height is set to and it lowers the landing to the level I started at. Just my workaround.
Nachricht 3 von 5
I didn't understand your workaround maybe for my bad english..Did you start with your the land or the staircase? can you easily repeat?
Nachricht 4 von 5
Like this?
Nachricht 5 von 5
als Antwort auf: ToanDN
I have the base set to the same variable as the relative height.
