Problem with revision numbers
Message 1 of 9
Hi, we are doing a project where revisions are required. Im quite new in the field, so I hope someone has the answer and solution.
I have created the revision schedule in the sheet family. Then in the model, when I want to insert a revision with comments on, lets say drawing A101, I give it the revision number 1.
When I want to insert a revision cloud on a drawing A102, with the same revision number, it gives me the same revision comments from drawing A101. Is there a way to fix it? Or did I miss something?
Basically, I want that all the sheets start with revision number 1, but with different comments, and no relation to each other.
Thanks!
Replies (8)
Message 2 of 9
Open the revisions dialog and change to Per Sheet, not Per Project.
Message 3 of 9
I tried that, yet it doesnt work. Each sheet with the same number, gets the same comments etc.
Message 4 of 9
You have to place the revision cloud of the correct revision sequence, or edit the Show Revisions on Sheet from properties and check the right ones.
Message 5 of 9
It doesnt work for me, not sure what Im doing wrong here.
Message 6 of 9
Did you create different revision sequences in the revisions dialog?
Message 7 of 9
Yes, but the revision number is still the same, so revision number 1 on drawing A101, is the same revision as revision number 1 on A102.
Message 8 of 9
Select the cloud on A102, look at the properties, and see what revision sequence it is.
Message 9 of 9
Oh thanks, I get it now, I just thought there was a way to put comments and not have to create a new revision sequence for that.
