problem with interior rendering
Message 1 of 16
I have a problem with interior rendering. I got always 100% dark result. In other words, the sun and light don't work. I checked the following:
- Sun setting is good.
- The light source is available in the light family.
- The material around the light source is glass.
- All the lights are ON.
- (Adjust Exposure) is good.
- In Edit Type of the light I tried several choices of Initial Intensity.
- In rendering window I tried all choices.
What can I do more to get a normal interior rendering?
PS: -Exterior rendering does normal except the lights don't work.
      - The rendering in all choices took unexpectedly very short time. But of course the result is totally dark image.
Thank you
Replies (15)
Message 2 of 16
dzanta
can you upload the revit file so I can look at it?  It may be just a minor setting within the Revit rendering dialog box...pick a lighting scheme of "Interior:...".  Make sure all artificial lights are Checked within the Artificial lights dialog box to ensure they are turned on...Double check project location via Manage, Location
(EEJan17...for contest)
Dzan Ta, AEE, ASM, ACI.
Autodesk Community | Twitter | YouTube | Facebook | LinkedIn |
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
Message 3 of 16
Thank you for your response.
I tried to send you the file but I couldn't but I got always this notice (see the attachment)
Message 4 of 16
dzanta
strange...try attaching revit file again and uploading....
if that does not work....
https://www.dropbox.com/sh/7b6iaxmfcnj9lrm/AABZVsna4TfDiZyO200LUtWVa?dl=0
upload to my dropbox....
Message 5 of 16
I uploaded the file under the name (Render experiment).
I hope it worked. I don't use dropbox so often. sorry!
Message 6 of 16
dzanta
i do not see any file attached or in my dropbox...please try again.
Message 7 of 16
Use this setting:
Message 8 of 16
I tried all possibilities and the same result. see the attachment. see also an image the view which I wanted to experiment the rendering on it.
Message 9 of 16
What happens if you change the 3d view mode to Realistic and Raytrace?
Message 10 of 16
see the attachments
Message 11 of 16
dzanta
is this issue happening only on this one revit file?  can you reproduce the issue with any revit fie?  can you reproduce the error on any workstation...not just the current one?
Message 12 of 16
Before I could render several interior sights. but I don't know what happened in the last time and I faced this problem with this and other files.
By the way, if I you don't mind to provide me with an e-mail that I can share this file with you via dropbox or e-mail.
Message 13 of 16
dzanta
try the following link to my dropbox account:
[email protected]
Message 14 of 16
I tried an other way. The file is on this link. I hope that you can open it. thanks
https://www.dropbox.com/s/i7ht2t7l6x4313h/Render%20experiment.rvt?dl=0
Message 15 of 16
dzanta
I have the file now.  The problem is because your camera is placed inside the wall.  I moved the camera to the corner of the room (inside the room) instead of within the wall.  The rendering is no longer black...I tested the rendering in draft and medium level with sun/artificial interior settings.  Since I am running 2017 Revit, you will need to make the change to your file and then you will be good to go...
Message 16 of 16
OOPS!!!
Thank you for all your responses.
I didn't expected such possibility so long I can see the interior scene.
It does perfectly as before.
Thanks again.
