Linked Revit Models
8 ANTWORTEN 8
GELÖST
Nachricht 1 von 9
KraiggC
514 Aufrufe, 8 Antworten
Linked Revit Models
Good Mornings,
Is there an ability to edit the link options? Primarily I want to be able to Link a model and NOT have it turned on in views. I have ALOT of sheets, and it would save me probably half an hour by turning on the model in the views I want them instead of turning them off. Thanks in advance.
8 ANTWORTEN 8
Nachricht 2 von 9
dzanta
als Antwort auf: KraiggC
Probably the best way to do this is to create a view template that has the linked revit model turned off and apply this view template to all of your views...If you do this however, you will override any current view template assigned to each view.  Usually, I would create a view template for each type of view (plan, elevation, section, etc.) and have the linked revit model turned off.  Hope this helps...
(EEJan17...for contest)
Dzan Ta, AEE, ASM, ACI.
Autodesk Community | Twitter | YouTube | Facebook | LinkedIn |
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
Nachricht 3 von 9
KraiggC
als Antwort auf: dzanta
Unfortunately no. I have view templates applied to all the views but I can't have the Revit Links applied due to all the floors requiring a different link view that needs to be used.
Nachricht 4 von 9
dzanta
Then it looks like you will have to select each view to turn the revit links off....you can perhaps try using Filters.
Nachricht 5 von 9
KraiggC
How do I use filters to turn links on and off?
Nachricht 6 von 9
dzanta
my apologies...double checked...cannot use filters (linked revit file is not a category).
best approach is using view templates.
Nachricht 7 von 9
Put the link in a workset that is set as invisible by default. You can
manually make it visible for only the views you need.
Nachricht 8 von 9
RDAOU
HI @KraiggC ...
Would placing the the linked model on a designated Workset help sort your issue? You Can set it to not show in all views an switch it on in the views you need?
Not ot ideal but at this stage of the project might help u sort things out
Tags (1)
Nachricht 9 von 9
dzanta
als Antwort auf: ToanDN
forgot about worksets...that will work
