Problem with floor plans showing same walls
6 REPLIES 6
ammg6c
274 Views, 6 Replies
So two of the floor plans in my model have been showing the exact same walls. I checked the visibility settings and they are fine. Whenever I delete a wall from one floor it deletes the wall in the floor both below and above. I even checked walls to make sure that the range are only within those floors and they are, in fact they are different walls. I also noticed that one of those two levels are not showing up in section view as a level but shows up as a floor plan. Please help!
6 REPLIES 6
in reply to: ammg6c
Does you view have Underlay turned on?
ammg6c
in reply to: ammg6c
No, underlay is turned off
ammg6c
in reply to: ToanDN
ammg6c
in reply to: ToanDN
No, underlay is turned off.
in reply to: ammg6c
What's the Associated Level of the two Plan Views.?  Maybe one is a duplicate of the other.
ammg6c
in reply to: barthbradley
Both are showing up as being associated with its designated levels like Level 5 is associated with level 5 and level 6 is associated with level 6
