Message 1 of 9
Problem with annotation tags when roatating scope box
06:39 AM
- Mute
- Permalink
- Report
My problem looks like that.
I have a main view of a whole building with dimensions, spot elevation tags and so on.
Parts of the building are at different angles so to make them straight on the sheet I copy my main view as dependent few times, and apply scope box to each. Then rotate each scope box.
While dimensions or door tags that follow in orientation hosts, rotate ok, there are some elements that don't.
- text element of spot elevation tags. Graphic part is correct.
- curtain panel tags, with applied angle parameter
- stairs tags that are rotated inside a family
Is there any solution for this ?
