Rotating parking tags?
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
1873 Aufrufe, 4 Antworten
Is there a way to rotate parking tag instead of using defined vertical/horizontal orientation? It's absurd it's so hard to do. Normally there's a special option "model" for tags (still silly if you ask me) but it's not there for parking tags.
4 ANTWORTEN 4
Nachricht 2 von 5
RobDraw
als Antwort auf: Anonymous
It might be silly of me to ask or even absurd that you might not have checked this but have you checked this?
Rob
Nachricht 3 von 5
Corsten.Au
Hi
You may use a nested annotation family in parking and control the numbering of parking using
instance parameter which maps " annotation family " instance parameter ( text of number. )
this way you can rotate the parking family in any angle ..
nested instance parameter " annotation family "nested instance parameter " annotation family "
Corsten
Building Designer
Nachricht 4 von 5
als Antwort auf: RobDraw
@RobDraw - Yes I did. It does not work as expected nor it does let me rotate the tag as I'd like to any regular element. No need for sarcasm if it doesn't help.
@Corsten.Au - Thanks. Just as I thought - no "regular" way to do it but it does push my case forward.
Nachricht 5 von 5
RobDraw
@Anonymous wrote:
@RobDraw - No need for sarcasm if it doesn't help.
I was just following suit. You weren't being sarcastic?
What is this case you are pushing? I thought you were here for help.
Rob
