Hey there,
Since last night i have a problem with printing sheets, when i print a sheet i get a blank page. This happens directly to my printer as well when i want to print to PDF, same blank page.
There is no problem to print a current window or portion of current window but no sheets. In previous parts of this project the problem does not occured.
Is it maybe an adjustment that i dont know about or something??
Who can help me please.
Kind regards from belgium,
Tom
Hey there,
Tom
As @ToanDN mentioned with the zoom to fit idea, you may have modeled an element or moved an element and now it is out side of your crop view or crop region. A good way to check this is to go to your sheet and just click on the view, and see the extents of your view box. If it is way outside your sheet and a blue highlighted item shows up you may have a modeled element you need to clean up.
