COMPOUND WALL REVISION
1 ANTWORT 1
Nachricht 1 von 2
tstewart
334 Aufrufe, 1 Antwort
How to delete/modify the upper part of this compound wall? The Water table is Masonry w/ stone cap and above that  is the siding.
1 ANTWORT 1
Nachricht 2 von 2
martijn_pater
als Antwort auf: tstewart
Function layer priority order needs to be 543212345 ie. Did you use split region?
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2016/EN...
