problem importing Sketchup model-
Good day
I have a large file done n skecthup. The architect sent it to me. I need to place the LED lighting and render the model. However i cannot seem to import the model and create a 3D model in the render.
I cannot change the origin and move to 0,0,0 on they Axis and i cannot get all the textures imported either. I need to create a family or something. Please help me with this.
It Is a big file and i dont know how to create a download link so please let me know where i can mail it to via Wetransfer if possible
So you cannot Import the SKP into Revit at all?  If so, maybe it's not a compatible version.  Do you have AutoCAD? If you do, you can Import Sketch into AutoCAD via the free "ImportSKP" Add-in, then save that DWG and Import that DWG into Revit.
lucdoucet_msdl
@Anonymous
Could you give us details of your setup and workflow?
1. What version of Revit are you using?
2. Are you linking a SKP file (INSERT | LINK CAD | SKP) or using the Autodesk App for importing SKP files?
Revit Help - Linked SKP
App Store - Import SKP
3. What is the file size of the SKP
4. Do you have Sketchup? If yes what version?
5. Do you have Autodesk FormIt Pro?
https://formit.autodesk.com/blog/post/using-formit-to-get-sketchup-data-into-revit
6. Are you trying to import to Revit then export to render in 3ds Max?
https://forums.autodesk.com/t5/3ds-max-modeling/cannot-import-and-model-skp-file-even-saved-in-2015/m-p/9757708
Depending on your available tools, different solutions are possible.
I would suggest to divide the SKP into multiple smaller files and import them successively rather than all at once.
-luc
_Vijay
Go to IMPORTCAD  and select as in below image.
Vijayakumar
Head of BIM
Did you find this post helpful? Feel free to like this post.
