Wall detail not showing in plan view
4 REPLIES 4
2845 Views, 4 Replies
I've moved from autocad to revit. And I'm really new into revit interface. I found revit more effective to bost my working time, I think.
So, the problem is, I really new into this stuff. I started to watch tutorial, and then in the first time I tried revit, something wrong happened. I can feel it. And after I zoom closer into my wall details, there aren't any hatch in it. When this tutorial guy started to draw a line, the hatches is coming within the wall simultaneously. And mine wasn't.
So, I give y'all my screenshot. I've already been looking for the solution in the forums. But none suit to my case. I hope you can help this fixed.
Thanks.
Labels (1)
4 REPLIES 4
mauricio_mssf
You need to change your visual style, It's in wire frame, put on hidden line, or consistent color.
After that you can change de level of detail from medium to fine. 
If the answer solves your problem, click Accept as Solution this helps other users to quickly find an answer and let a like if you liked it.
Você achou esta postagem útil? Sinta-se à vontade para curtir esta postagem.
Ficou satisfeito com a resposta à sua pergunta? Nesse caso, clique no botão ACEITAR SOLUÇÃO.
 Mauricio Santos Filho Arquiteto | BIM Manager
Cut Pattern Linework??? Go to Level 1. Do you see hatches?  Site Level's View Range is typically set  high above the building and is not cutting through anything.
in reply to: mauricio_mssf
Thank you so much. It's working !
in reply to: barthbradley
Not an issue. My problem was actually I didn't set the detail level and visual style. It's solved tho. But thanks for your reply 😁
