Problem exporting rvt files with images into dwg
jjjoao2
jjjoao2
I´m trying to export these revit files in to dwg files but, for some reason, it is not exporting the image below.....but it exports great to PDF file. Any suggestions?
Many thanks. 
PDF exporting
DWG exporting
@jjjoao2  Please uncheck below option in DWG/DXF Export Setup.
Please see below capture image.
Thanks & Regards,
RJ
Many thanks. 
PDF exporting
DWG exporting
jjjoao2
@Anonymous, it worked with 90% of the sheets....for some reason it didn´t work with the rest.
Thank you very much for your help.
