Hello everyone,
I have an Rvt "mother file" with two rvt linked files and i need to export them as one into a IFC file.
When i did that, it only opened the Rvt "mother file"...and left a blank space of the two linked files.
How can i export this whole project to became a single IFC file?
Many thanks
Gelöst! Gehe zur Lösung
Gelöst von L.Maas. Gehe zur Lösung
Hi @jjjoao2
You can't directly, you have to convert the links into groups (link tool). I recommend that you do not do it in your usual work file but do a Save as and in that copy "links".
1. The steps would be:
2. Another alternative outside of Revit is to load all the links into Navisworks and export them to a single IFC with Codemill IFC Exporter.
Luck ![]()
Jamhmer Oc
Short answer, you can not. There are no settings for this. The only export option you have is to export the linked IFC files. But they sill will be exported as separate files.
Normally you only want to export your own parts and not the content of others (linked files). Those files are under responsibility of those parties and they should make their own IFC's. With coordination software (e.g Navisworks) you would bring those files together in a single file for clashing and so on.
Longer answer you could bind the Linked IFC's in your Revit file, making it a single Revit projects. For this you would first need to open The IFC (resulting in an rvt file) and this file can be imported into Revit. WIth the single Revit file you can export a single IFC
Other route might be to merge the IFCs. There seem to be some third party tools who can do this.
Louis
Please mention Revit version, especially when uploading Revit files.
"2. Another alternative outside of Revit is to load all the links into Navisworks and export them to a single IFC with Codemill IFC Exporter."
I´ve downloaded the Codmill IFC Exporter for Navisworks, but after exporting and opens in Revit....there´s no model, it´s like empty.
Is theres any previous configuration in the IFC Exporter?
