- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi fellas!
I need to adjust the height of an assembled stair, thought this would be an easy task but I run into a bunch of problems when trying. Three errors:
"Cannot create specified fillet for rail join(s). Please try a different value."
"Cannot create specified fillet for rail join(s). Please try a different value." and
"Stair top end exceeds or cannot reach the top elevation of the stair. Add/remove risers at the top end by control or or change the stair run's 'Relative Top Height' parameter in the properties palette."
This is in Revit 2016.
Anything I should do in a specific order or change?
Right now I've started with adjusting the "Base offset" from -250 to -470.
