Printing filled regions in families
4 REPLIES 4
p_barnett
521 Views, 4 Replies
I've created an escape sign family and inserted a detail family of the sign graphic using filled regions. We've placed this family in Revit 2018 and 2020 models. They view correctly on screen.
Keeping the scale at 1:100, at full sheet they print as empty rectangles. If I zoom in on screen and print 'visible portion' there is a point at which the preview shows the contents of the families.
If I select all of the signs and isolate them (everything else turned off) they will print at full sheet.
If I turn Raster printing on, that solves it. But it appears to be they get turned off at an unknown amount of complexity in the drawing.
Seems to be an ad-hoc solution. I'd like to know if anyone knows the true cause (lack of RAM?) or are we waiting for Autodesk to solve?
4 REPLIES 4
in reply to: p_barnett
Solve what?
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2019/EN...
Redrunner92
I'm no authority on this topic, but just from experience I've noticed this pattern throughout Revit views, whether printed or viewed on-screen. It seems like a view, when printed, does the same as it does when zooming in and out on-screen: at some unnamed zoom-out level, it increasingly simplifies the patterns until ultimately not showing them at all. And the raster printing makes sense with this since, as far as I know, it sees such filled regions as "colors" rather than how vector printing sees them as a pattern made up of multiple lines.
What do you mean by "at full sheet"? Does the printed view zoom in on these items, or do they stay at the same scale yet print fully on Vector printing? Or do you mean something else?
p_barnett
in reply to: barthbradley
Inconsistency.
Print the drawing out and finding that it didn't print this time, but it worked fine on a different drawing. Having to change settings and do it again. There is an unknown point at which it stops working and you have to change settings.
It can detect raster images (shaded views &c.) and inform you that 's going to swap. It would be good if it could detect that it couldn't cope and inform you that it needs to swap.
p_barnett
in reply to: Redrunner92
Hi, in all the tests I did, I kept the scale at 1:100, but by zooming in and out and printing 'visible portion', I was changing the amount of content to be printed, not the detail/ quality it was printing. By full sheet, I meant the 'Current View' option.
Cheers
Forma Design Contest
Technology Administrators
