ISSUE WITH EXPORTING PROJECT PARAMETERS TO IFC
1 ANTWORT 1
Nachricht 1 von 2
368 Aufrufe, 1 Antwort
I was to export Project Parameters that I've assigned to my Model Elements into IFC. But am unable to view the same once the export is done.
Please find my export method below in the form of screenshots and suggest a remedy for the same. I've created a Project Parameter under Text called Test_ID and assigned value for the same for all the elements.
1 ANTWORT 1
Nachricht 2 von 2
TripleM-Dev.net
als Antwort auf: Anonymous
The "Test_ID" parameter is not a "Common property".
So change the exportsetting to include "Export Revit Property Sets", this will export ALL parameters.
If you want control over which parameter is exported or not then look into "Export user defined property sets"
- Michel
