PRINT DELIMA
PRINT DELIMA
Message 1 of 17
PRINT DELIMA
I am trying to make a a print and when I press cntrl + P and then I want to select the 'preview' and or 'select' and or 'setup' which I have higlighted in yellow it doesnt work . I never had this issue before and it is quite a new problem.
Replies (16)
Message 2 of 17
ennujozlagam
@Anonymoushello mate. I didn't experience what you had experienced in printing. see screencast. thanks
try to install altest updates from autodesk.
Message 3 of 17
Keith_Wilkinson
Have you tried selecting another printer to see if the problem exists there as well?
Also, have you tried restarting Revit and/or the computer?
"Give a man a fish and you feed him for a day; teach a man to fish and you feed him for a lifetime."
Maimonides
Message 4 of 17
ennujozlagam
@Anonymous my apology, i misunderstood your question. thanks
@Keith_Wilkinson
i think what he wanted is when you select the "selected views/sheets" the preview is also highlighted that you can see the preview, which is not possible.
Message 5 of 17
Keith_Wilkinson
No, preview with selected Views/sheets isn't an option - never has been as far as I'm aware.
The original question reads that all 3 options are not available but maybe I'm misunderstanding it.
Maimonides
Message 6 of 17
I have restarted the systme and also revit but stil th eproblem persists. Might try to reinstall revit.
Message 7 of 17
How do i update revit?
Message 8 of 17
hi mate. the options you press and opens up is frozen in my revit
Message 9 of 17
ennujozlagam
@Anonymous hello mate, i think you need to install latest updates and could solve your issues. if you are under autodesk subscriptions just go to your autodesk account HERE and log-in. please see attached. thanks
Message 10 of 17
Keith_Wilkinson
can you just clarify exactly what the problem is?  Are you unable to select any of the 3 buttons you've highlighted in your original post?
Maimonides
Message 11 of 17
That's exactly what I said as I said I am unable to press the highlighted
buttons
Message 12 of 17
Keith_Wilkinson
Have you tried selecting a different printer?
Maimonides
Message 13 of 17
RDAOU
@Anonymous
If I were you, I would follow @Keith_Wilkinson advice and select another printer...the print to PCP doesn't give you access to those options and I do not believe it is for printing from REVIT or any other AEC Platform.  .PCP stands for Patch Creation Properties!
I think you were most probably intending to use PDF print
Message 14 of 17
yes i have selected a differnt printer but th eproblem still persists. in fact my revit behaving strangely in many othetr way s as well.
Message 15 of 17
Keith_Wilkinson
Well if it is the same with all your other printers then I'd go for the notion that your install is corrupt.
You could try running a repair on it (you should get this option if you run the installer again before uninstalling Revit) or as has also been suggested check your version is fully up to date in terms of Updates.
Maimonides
Message 16 of 17
ennujozlagam
@Anonymous hello mate, have you resolve your issue? if not you can try this "Uninstall (Windows 7) KB 3177725 and (Windows 10) KB 3176493" see if this helps. thanks
Message 17 of 17
Sorry for late reply. I tried all methods which were suggested here but unfortunately non of them worked . I just save each sheet as a pdf seperately.
By pressing control P them select preview then save as PDF.
