Adding rotation parameter to an imported dwg in a family
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
edgars_miskins
1208 Aufrufe, 3 Antworten
Hi.
I need to add a rotation parameter to rotate imported dwg model within a revit family. How would I do that?
I tried:
1) imported the dwg model
2) exploded it and grouped it together with a reference line.
3) locked the group center to reference planes
4) added angular dimension between ref line (grouped) and one of the ref planes.
5) added angular parameter
In the end I am unable to change the parameter value.. But when I try to rotate the group manually, it rotates just fine.
What did I do wrong?
3 ANTWORTEN 3
Nachricht 2 von 4
nathan.chapman
als Antwort auf: edgars_miskins
Dwgs can be tricky.  What you should do is import the dwg into a family and then nest that family into another.  When you add your rotation parameter remember to snap the angular dimension to the reference plane in the nested family NOT geometry or it wont work.
Nathan Chapman
Production Manager at General Heating and Air Conditioning
Revit Architecture Certified Professional
Revit MEP Mechanical Certified Professional
Revit MEP Electrical Certified Professional
DynaFabrication Package Author
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the KUDOS button.
Nachricht 3 von 4
edgars_miskins
als Antwort auf: nathan.chapman
I tried to nest another family.
But then I run into the problem where the nested family cannot be rotated the way I need it.
Nachricht 4 von 4
edgars_miskins
Found a solution.
The nested family idea was the correct approach. Thanks!
However this needed few more things. Here is what I did:
1) Started with empty generic model. Created a single ref line with one end locked to both origin ref planes.
2) Created an angular dimension with a parameter between the ref line and one of the origin ref planes.
3) Made the family containing the dwg into a workplane based and turned off "Always vertical"
4) Inserted the dwg-containing-family into the empty family choosing "Place on Work Plane"
5) Edited the workplane of the nested family and set it to the ref line.
And it works!
