Precast Column and Panel Modeling
hliS658H
Message 1 of 28
hliS658H
There is a notch in the column where two panels meet with the column, the panels will be pocketed inside the column; the column and panels will be aligned on the exterior.
I know the structure engineer will develop the above details. But how can I model it and the elevation will look right?
Is it possible to create a column family, whenever it meets the wall, it will generate a pocket? What is the best way to model a building with this type of connection?
Accepted solutions (4)
Replies (27)
Message 2 of 28
Notch the column and Join it to the Wall in the correct Join Order.
Message 3 of 28
Actually, you can create Parts from Wall, Divide and Notch via Division Profile.
https://knowledge.autodesk.com/support/revit/learn-explore/caas/CloudHelp/cloudhelp/2021/ENU/Revit-M...
Message 4 of 28
hliS658H
The notch is not all through the column, only where the wall panel meets with column. Do you have any suggestion on modeling this detail?
Message 5 of 28
You could create the wall as a curtain wall using the same basic wall type for panels.  Add grid lines at the joints to split the walls. Then join the wall panels with columns to notch the columns.
Message 6 of 28
hliS658H
How can I create curtain wall with basic wall type? Curtain Wall is system family,  how to change glass to concrete?  Is it possible to set the grid as void?
Message 7 of 28
Edit the curtain wall type and change the default panel type assignment to a basic wall type.
Message 8 of 28
So, that horizontal member is a Wall and you want it to cut a notch in the Column? If so, why can't you join the Wall to the Column to create the notch?
Message 9 of 28
hliS658H
I use "join geometry", the wall panels don't cut notch in column so to only show wall material on the exterior finish, we still see the column material on the surface.
Message 10 of 28
hliS658H
Do you have to manually leave a gap between the two wall panels?
Message 11 of 28
Share you file here because I can cut the column without issue.  Or see the 2022 file I posted.
Message 12 of 28
hliS658H
1. The reason to use curtain wall instead of regular wall is to create joints through curtain wall grids?
2. I realized the reason the wall and column didn't join is because I already set the column not join to wall automatically.  So I like the approach, but the only concern is the graphics in plan - I need to make column and wall separated. The needs  conflict - in plan I don't want the wall and column to join; but for elevation, I need them to join so the wall can cut the column a notch and show correctly.
Message 13 of 28
As I mentioned above, you can make that gap quite easily via Create Parts and Dividing Parts.
Message 14 of 28
Message 15 of 28
hliS658H
Did you solve the conflict by using structural column?
Message 16 of 28
I always use structural columns when they are load bearing.
Message 17 of 28
hliS658H
What makes the column keep the graphics of solid hatch even after joining the wall panel in plan?
Message 18 of 28
hliS658H
Can you share your file here? Also, with your approach, is there way to keep column's solid fill so it doesn't merge with wall in plan?
Message 19 of 28
A detail component nested in the structural column family.  Open the Revit file and edit the family.
Message 20 of 28
hliS658H
How are you able to insert a detail family into a structure column family? I am trying to insert one into the architectural column, it doesn't allow.
