Difference between Create New Project and Create New Project template?
2 ANTWORTEN 2
Nachricht 1 von 3
epolydorou01
297 Aufrufe, 2 Antworten
What is the difference between Create New Project and Create New Project template?
2 ANTWORTEN 2
Nachricht 2 von 3
HVAC-Novice
als Antwort auf: epolydorou01
Check out what templates do... and create one that works for YOUR needs.
https://knowledge.autodesk.com/support/revit/learn-explore/caas/CloudHelp/cloudhelp/2021/ENU/Revit-C...
The one creates a project, the other a template (you probably could see that :-). You can create a project from the template, or a project can be saved as a template.
Revit version: R2025.4
Nachricht 3 von 3
One creates a new RVT file format and the other creates a new RTE file format.
