Range of embbed between Curtain Wall and Other Wall
14 ANTWORTEN 14
Nachricht 1 von 15
Vuxvix
730 Aufrufe, 14 Antworten
Hi!I'm having a little trouble controlling embbed the Curtain wall.
In the example:
2 walls running in parallel (ALC and Basic wall inner). when I create a glass frame with Curtain Wall (CW) located on the Core Center of the inner wall, Revit creates an open wall for the CW. when I offset CW below 200mm the Open wall still shows. But above 200mm its gone、 So i need edit profile Basic wall.
Is there any Parameter to control this range of embbed?!
14 ANTWORTEN 14
Nachricht 2 von 15
als Antwort auf: Vuxvix
Shouldn't be acting that way. I'm thinking a Hidden Constraint possibly. Post the fie so we can see what's going on
Nachricht 3 von 15
Vuxvix
als Antwort auf: barthbradley
Thanks for your help
Nachricht 4 von 15
The range is 20cm.  If you want separate them farther apart, then create an empty curtain wall and constrain the size to the real curtain wall, to cut the wall.
Nachricht 5 von 15
Vuxvix
als Antwort auf: ToanDN
Hi!
 My goal in this is to optimize the operation. So, creating or editing profiles takes more time.
Thanks for your suggestion
Nachricht 6 von 15
I'm not sure what you are trying to achieve here. Can you elaborate?
Nachricht 7 von 15
I didn't suggest you to create or edit profile.
Nachricht 8 von 15
Vuxvix
I don't quite understand what you want to know
Nachricht 9 von 15
Vuxvix
Creat more CW (ur suggest) or edit profile (my current way).
Nachricht 10 von 15
Well, if you look at my screenshots, you can see the CW extended all over the place - top, bottom, left, right - without affecting the window opening location or cut-through in the parallel Basic Wall.  Is this what you what to achieve?
Nachricht 11 von 15
Vuxvix
In many other cases. The distance between the 2 walls will be even bigger. example is 300 or 400. Then the position of the CW will also move further away from the Basic Wall. Then the open wall will no longer exist.
Nachricht 12 von 15
Say what???
Is this what you are after?  A window jamb extension?
Nachricht 13 von 15
Vuxvix
CAN YOU SHARE HOW YOU DO THAT!?
Nachricht 14 von 15
Is that seriously what you want???  An automatic jamb extension spanning the empty space between two wall types?
Nachricht 15 von 15
Vuxvix
1- i am looking for a way to keep the embbed of the CW with Basic wall when the offset distance increases.
2- In addition, I also have a problem with the size of the border mulions -jamb extension (because the distance between the 2 walls changes at different locations). Currently I have to create a lot of family types with different widths. If I can do it like this, it will help me a lot
