plumbing/pipe callouts
5 REPLIES 5
htews
236 Views, 5 Replies
Here is a dumb question....I can't seem to get pipe callouts to show or load.
5 REPLIES 5
vitorbortoncello
in reply to: htews
  • Make sure that the pipe category and subcategories (like pipe fittings, pipe accessories, etc.) are turned on in your view.
  • Go to View > Visibility/Graphics (or use the shortcut VG) and confirm that these categories are checked.
  • If the callouts aren’t loading, you might need to load the appropriate family.
  • Go to Insert > Load Family and navigate to the appropriate folder (usually under Annotations or MEP categories) to load pipe tags.
htews
in reply to: vitorbortoncello
I found it.  my mistake.
htews
in reply to: htews
i'm at a loss....i'm trying to show both inches and mm in the same tag.
htews
in reply to: htews
is there another way of doing this - showing millimeters?
vitorbortoncello
in reply to: htews
You need to add two labels: one with the orginal units, and another with the alternative unit as show below.
