plumbing/pipe callouts
htews
htews
Here is a dumb question....I can't seem to get pipe callouts to show or load.
vitorbortoncello
  • Make sure that the pipe category and subcategories (like pipe fittings, pipe accessories, etc.) are turned on in your view.
  • Go to View > Visibility/Graphics (or use the shortcut VG) and confirm that these categories are checked.
  • If the callouts aren’t loading, you might need to load the appropriate family.
  • Go to Insert > Load Family and navigate to the appropriate folder (usually under Annotations or MEP categories) to load pipe tags.
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | Especialista BIM
aAutodesk Certified Professional
htews
I found it.  my mistake.
htews
i'm at a loss....i'm trying to show both inches and mm in the same tag.
htews
is there another way of doing this - showing millimeters?
vitorbortoncello
You need to add two labels: one with the orginal units, and another with the alternative unit as show below.
