Plaster Bands around Openings
AidanHawkins
Message 1 of 10
AidanHawkins
I am trying to model something like this around wall openings..
Should I just model around the opening with a 25mm plaster wall and join it to my existing wall?
Replies (9)
Message 2 of 10
siddharth.achaya
It depends how many of these you have to make.
If it's just one or two, yeah, I'd go with making a separate plaster wall type around with an edit profile.
If it's a hundred (lol), then maybe make a quick face-based family?
You could add parameters for LxB of the opening, offset distance from the opening, width of the band and thickness of the band...
Message 3 of 10
Simon_Weel
If the openings contain a Door or Window, you could add the plaster bands in those families. For openings without door or window, you can still use a Door or Window family to create the opening and add the plaster band as well.
Message 4 of 10
syman2000
Why not build a opening family with the built in band? See attached
Message 5 of 10
Do you want it to join to the wall?  Or it can just be like a door trim, but made of plaster?
Message 6 of 10
AidanHawkins
yes I thought of that but can I then place a window in the same place as the opening?
the plaster bands are existing
Message 7 of 10
AidanHawkins
just like a door trim, made of plaster, it doesnt have to be part of the wall
They are existing, so I think It is best to keep them seperate to the windows which I will be changing in the new construction
Message 8 of 10
syman2000
Yes you can.
Message 9 of 10
Model as a door family without opening cut, just the plaster band.
Message 10 of 10
siddharth.achaya
posting from the correct id (also notified mod to remove the other ones) -
@ToanDN pretty much summed up what I had suggested - make a face-based family.
I would think even if you want to give it a door identity (since there is a general aversion to leaving something generic category), I feel it might be better to model it using a generic face-based template, and then give it whatever category you want  - door/window/other...
If you model it symmetric around the Centre ref-planes in the template, you can use those to align it with the windows that you have placed... (might have to do it in an elevation though)
