Plans going to wrong category
Sahay_R
Mentor Mentor
Sahay_R
When I create a plan view from levels added to an elevation, it goes to the wrong category which makes searching for them in the browser a challenge. I know it's an easy fix - we just have to switch over to the correct template - but it's annoying all the same. I hope that someone can solve this!
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Accepted solutions (3)
You can change the template while creating a new view.
Sahay_R
True. That's the one extra step we want to avoid.
Rina Sahay
alan.quinn
As ToanDN pointed out, if you change your Template (the first time) and choose the Category you want it will retain that setting. Each new Plan View you create will be placed in the Category you picked.
Hope this helps and thanks for posting.
Sahay_R
Perfect! Toan and Alan - thank you!
Rina Sahay
chrisplyler
If you want your template file to already have the correct setting, open the template file, change the setting, then re-save it as a template again.
Sahay_R
Done!
Thank you, Chris!
Rina Sahay
