Column Grid Bubbles
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
PhilvK
2462 Aufrufe, 5 Antworten
Column Grid Bubbles
Can column the location of the column grid bubbles vary from view to view? When I have a 16” scale plan and move them out, they are too far out for a 1/8” view.
5 ANTWORTEN 5
Nachricht 2 von 6
als Antwort auf: PhilvK
Nachricht 3 von 6
PhilvK
als Antwort auf: ToanDN
Dang...yes, I forgot!
Nachricht 4 von 6
PhilvK
I have also seen the grid bubbles 'move' with the crop box, but can't seem to duplicate that behavior. When / how does that occur?
Nachricht 5 von 6
Alfredo_Medina
It occurs when the crop region is active. The crop region could be there but inactive, not cropping the view. In that case it has no effect over grid lines.,
Nachricht 6 von 6
PhilvK
als Antwort auf: Alfredo_Medina
Thank you for your response, but I am still not understanding this.
On one view, the bubbles moved with the crop region until I manually adjusted the bubbles, which were set to 2D. After adjusting them, moving the crop region has no effect. On another view, turning on the crop region and moving it had no effect on the bubbles. I still can’t figure the ‘rule’ when they move and when they don’t. Do you know of any videos explaining this?
