Plan Visibility Question
9 REPLIES 9
Message 1 of 10
505 Views, 9 Replies
I've attached the Revit file in question.
There is only a single floor plate in the model, and 3 plan views - Floor 0, Floor 1, Floor 2.
The floorplate geometry can be seen from the floor plans of Floor 0 and Floor 2, but not Floor 1; I can't figure out why.
As far as I can tell, all visibility and view range settings are identical.
Seems like a simple enough question, but multiple seasoned Revit users have been unable to pinpoint the cause of this issue.
Thanks!
9 REPLIES 9
Message 2 of 10
Sahay_R
Right click on the vie win the Project Browser>>Apply Template Properties. Change the view type filter to All.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Message 3 of 10
in reply to: Sahay_R
I don't understand.
The View type filter only helps me select templates to apply; it doesn't actually make any changes to the model.
I'm not sure what solution you are suggesting and how it is supposed to help.
Whilst I understand that replacing my "Floor Plan: Level 1" view with a completely new plan may solve the issue, I am more curious as to why this specific view fails to show the desired geometry. I am much more interested in the cause than the fix.
Message 4 of 10
Sahay_R
Have you tried to click per my screenshot? Because when I did that the floor (along with another couple that I had created to test) appeared.
Rina Sahay
Message 5 of 10
I have followed your instructions to no effect.
Furthermore, I don't seem to understand your instructions.
You say to right click the view - "Floor Plans - Level 1", then "Apply View Template", then change View Type Filter to "All".
There should be more steps afterwards. After selecting all, I am given the choice between Architectural Elevation, Architectural Plan, Architectural Section, etc. You haven't told me what to choose.
Furthermore, I have tried Architectural Plan, clicked Apply Properties, and the geometry still fails to show.
Message 6 of 10
Sahay_R
Click on All - that is what was highlighted in the screenshot. Another approach that I have tried was to delete the level and recreate a new level with a view. When I associated the template with the view, the geometry showed up. Please see the attached file of this solution. Sometimes when views misbehave (and a lot of times it defies understanding), the best thing to do is recreate them.
Rina Sahay
Message 7 of 10
I understand what you are saying,but once again you are missing instructions.
In the "Apply View Template" box, I have chosen "<all>" in View Type Filter, but then I need to choose the name of a single template correct? Within the list is Architectural Elevation, Architectural Section, Site Plan, Etc. Which would you like me to select? If I simply click "<all>", it defaults to Architectural Plan, which is not a successful solution.
Furthermore, I know that by deleting and creating the view, I can fix the problem. But I am not looking for a solution. I want to know exactly why this view I currently have fails to show the geometry. I am not trying to fix the problem, but find out what is causing the problem. To recreate the view is the ignore the issue.
Message 8 of 10
Sahay_R
The View Template that I used was Enter New Name Here.
Once again, there are things that Revit does that are beyond understanding. Sometimes things that work do not work the next time! Having a workaround that works is what matters.
Rina Sahay
Message 9 of 10
I can't accept that as a viable answer. To work around a problem you don't understand seems dubious.
But thank you for your time and help.
Message 10 of 10
I found the issue.
I had originally thought it was a program glitch.
Turns out, my view "Floor Plan - Level 1" had Phasing set to "B10 Superstructure".
Once I set it back to "Project Comletion", it showed up.
