revit pdf printing problem
08:23 AM
Issue:It takes a long time to PDF plan views in Revit.
Causes:Overly complex modeling of families and the use of groups can significantly slow printing.
Solution:
- Ungroup groups
- edit families:
- avoid nesting families inside nested families;
- purge families;
- make 3D elements invisible in plan views, and represent the geometry with annotation lines instead
- use Revit native elements, and avoid the use of imported file types (.dwg, .sat, etc.) wherever possible
This is the response to the issue and this is acceptable? This seems to be the typical response and its getting old! I have a powerful computer and software but you are telling me not to use it so that I can use it. Please fix this!!!
I just took hours to print a project when it should have taken less than 5 minutes!
