Problem in sketching stairs
Message 1 of 8
Hi, I've been trying to sketch cast-in-place stair with sketch mode. When I saw it on the floor plan, it seems to be fine. My stair drawn like what I want. But when I switch to 3D mode, then the drawing getting weird. Is there any clue to fix this all?
I've been asked @Anonymous and @AutodeskHelp at Twitter, they suggest me to look on this page:
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2017/EN...
and I've been following the step on that web page, but the result is still the same.
Thanks.
Replies (7)
Message 2 of 8
loboarch
What does the sketch look like?
What are the stairs supposed to look like?
With that info i will be easier to help you resolve the problem.
Jeff Hanson
Principal Content Experience Designer
Revit Help |
Message 3 of 8
I've been attached my stair's sketch...
it suppose to be a simple stair's sketch
Message 4 of 8
Sahay_R
Share your file so that one of us can tell how far you've gotten and where you went wrong.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Message 5 of 8
loboarch
Ok, I tried creating something similar and got a similar result when using a monolithic stair. If I change the type to be an assembled stair it works ok. I suspect it has somethign to do with the 90 deg wrapping the stair is doing and the geometry not being able to resolve the underside of a monolithic stair.
I would suggest making it an assembled stair and changing some riser profiles and tread profiles to make it look more like a monolithic stair.
Jeff Hanson
Revit Help |
Message 6 of 8
Hi, I'm attaching my revit project here
Message 7 of 8
Change the Underside Surface to Stepped instead of Smooth.
Message 8 of 8
Thanks, it solve my problem
