Hello everybody,
I have a floor plan of a roof and I want to display lower objects in some regions. These objects came from a Navisworks link (coordination model). If I change the view range for all the view I can view what I want. But if I want to apply this view range to only a plan region I can't see the objects from the Navis.
Any idea?
Thanks very much!
André
Set the view range to the main view as you said, so you can see the Linked Navisworks elements then try applying the plan region around your roof and set the view range for the plan region as required.
